December 29, 200817 yr Mine does a 145.4 at 36 hz. It stays in the 143-145 range from 33-46 hz. This is in a Silverado with no sound dampening.
December 30, 200817 yr Mine does a 145.4 at 36 hz. It stays in the 143-145 range from 33-46 hz. This is in a Silverado with no sound dampening.nice ...on how much power ? have any videos ...
January 10, 200917 yr That Thing Should Be Hella Louder Than That. You're Only Running 1500 RMS To It Aren't You? That Thing Can Take 3000 Watts Daily. I'm Gonna Get One In My '87 Chevrolet Crew Cab Dually With A Sundown SAZ-3000D. Sub Behind The Passengers Head And Port Behind Mine. Ear-Screwed Either Way. xD
January 10, 200917 yr That Thing Should Be Hella Louder Than That. You're Only Running 1500 RMS To It Aren't You? That Thing Can Take 3000 Watts Daily. I'm Gonna Get One In My '87 Chevrolet Crew Cab Dually With A Sundown SAZ-3000D. Sub Behind The Passengers Head And Port Behind Mine. Ear-Screwed Either Way. xDu r going to smoke that sub with 3000D :clap:
January 11, 200917 yr That Thing Should Be Hella Louder Than That. You're Only Running 1500 RMS To It Aren't You? That Thing Can Take 3000 Watts Daily. I'm Gonna Get One In My '87 Chevrolet Crew Cab Dually With A Sundown SAZ-3000D. Sub Behind The Passengers Head And Port Behind Mine. Ear-Screwed Either Way. xDu r going to smoke that sub with 3000D :clap:Depends on the gains etc etc but i doubt it can take 3000 daily, very few subs can
January 11, 200917 yr if the company rates it @ 1500Wrms ...thats it ... i wouldnt give it more than 1.8-2.0 kW daily ...for burps yes ...i dont know why people think it can take 3kW or whatever for a long time ??(is it the size?) :Doh: :Doh: ...... every manufacturer of subs should write besides their rated powers for the subs ... if u power it more than it is rated(on a daily basis),you should order a recone !!! :drink40: Edited January 11, 200917 yr by Tyan
January 11, 200917 yr LOL iirc the BTL is rated 1500 (maybe 2k? i forget) but it can take much, much more.my lvl 4 is rated a 1,000w sub and i gave it 2,800w for the few weeks i had it in. Just because i was laughing so hard from last post- i'll end with this.speaker fails for two reasons thermal or mechanicalif your overpowering your driver you can build a box to compensateany woofer will burn with its rated power clipped to hell and over heatingWith clean signal and the right box you can overpower well built woofers quite a bit.Sorry for being off topic to the OP -Drew Edited January 11, 200917 yr by Noobtastic14
January 11, 200917 yr A clipped signal "contains" more power compared to a non-clipped signal of the same ampliture. The speaker doesn't care if the signal is clipped or not. Too much power will damage the coil. Doesn't matter if it's clipped or not.http://www.soundsolutionsaudio.com/forum/i...showtopic=24323Say no to myths !
February 11, 200917 yr i know this post is kind of dead and old but here is my 2 cents. Noobtastic is right. I have had an RE MT 18 sub in the back of my explorer for around a year. I have put around 5000 ~ 6000 Rms daily to it. I reconed it after a year of playing beacause i wanted to change the ohm load. coil still in great condition. But again we are talking SPL here. True competitors push their systems beyond their limits to post up a number.
February 11, 200917 yr A clipped signal "contains" more power compared to a non-clipped signal of the same ampliture. The speaker doesn't care if the signal is clipped or not. Too much power will damage the coil. Doesn't matter if it's clipped or not.http://www.soundsolutionsaudio.com/forum/i...showtopic=24323Say no to myths !true to a point, most woofers loose control when they are recieving a dirty signal from its power source. If the woofer is not controlled properly the coils cannot cool themselves properly causing the coils to overheat and eventually burn.
February 11, 200917 yr I agree with Drew too. If you overpower a woofer with clean undistorted power it should't fail unless it isn't properly cooling. Most subs have a decent cooling system and will take 2X the rms with no problems as long as you are not beating the piss out of it for 30 minute consecutive intervals. I know of several people running a saz3000d on 16 volts on a Nightshade and the NS handles it all day long. It has the same power ratings as the IA Dp subs and a saz3000d on 16 volts puts out around 5K watts depending on the impedence.
February 16, 200917 yr if the company rates it @ 1500Wrms ...thats it ... i wouldnt give it more than 1.8-2.0 kW daily ...for burps yes ...i dont know why people think it can take 3kW or whatever for a long time ??(is it the size?) :Doh: :Doh: ...... every manufacturer of subs should write besides their rated powers for the subs ... if u power it more than it is rated(on a daily basis),you should order a recone !!! :drink40:I have a customer with a 21 in a 10 foot box 160 inches of port tuned to 40 hz on a Kicker zx2500.1 for over a month and has not had a problem. And he is 16 years old so I know he isn't taking it easy. Also have two different other customers with DP 12's with 2000 watts rms and have had no problems. I am not saying it is true for every woofer but the DPs can handle more than 1500watts rms, from my experiences that is.
