Hey I was directed here by denim, I would like some help with some box plans for my 1995 Ford Explorer.
I am putting 6 RE 12" REs in there, I would like the box to be built to specifications and space needed for each sub that RE recommends. I am running a Viper 1200.1 amp, and having 200 watts rms @1 ohm to each sub.
I would like a cutsheet so I can design it
Max Measurements
Wide ---- 46"
Long ---- 28" (meeting back door from rear seats)
Tall ---- 10-12"
I would like my box tuned to however you think 6 RE 12" RE should be tuned to.
I listen to mostly rap, and want a mixture of SQ/SPL
I would like it vented, Dave from RE told me to put my subs facing the roof, and then put the vent going towards the back door, but this box is going to be so big the vent will meet the back door, so whatever you guys think is best, I think I will have like 2 -3 " clearance from vent to back door. Thanks so much
I will pay 10 bucks paypal if anyone will help once I get my debit card in, or for free if someone is kind
BlackHaze
Oh and I will be using 3/4 MDF wood for the cut sheet measurements to be exact
OK HERES A DESIGN...
Bandpass Prism Box Parts
1 Top, 1 Bottom: 46 x 12
0.75 (thick) in
1 Front, 1 Back: 23.5 x 12 0.75 (thick) in
3 Sides: 23.5 x 44.5 x 0.75 in
Baffle Location: 5.5, 4.25
Vent Parts
1 Top, 1 Bottom: 44.5 x 14
0.5in
2 Sides: 3.5 x 14 x 0.5in
I'LL TRY AND GET PICS OF THE GRAPH ...
80
U CAN ALSO PUT ANOTHER 1200WATTS AND THE SUBS WILL STAY WITHIN THERE XMAX LJMIT...WITH THIS DESIGN...AND U WILL HIT 150+DB'S
Alright well thanks for the graph once you get it just post and I can go from there, thanks for all your help :)
  • 1 month later...
is it possible to fit 6 12's on a box that size?the one im designin for 2 2000spl's is almost exactly that size and i barely got it to fit.....for 33 tuning
