Posted January 7, 200917 yr okay guys, i am lookin to build a new box for my 2 12" kicker cvr's, i am wanting around 34hz for tuning and here are the dimensions i have to work with, 39"w x 17"h x 17.5"d and plans would be great i am either looking for the port and subs facing the same direction or subs foward firing and port side firing, any plans would be nice, and i am looking for a slot port, i am not going to mess with a pipe since i dont have a hole saw, thanks in advance.
January 7, 200917 yr Author this will be going in an ext. cab f150 and removing the seat is not an option(no room in teh garage or house) so the box will just sit on top of it
January 8, 200917 yr he's looking for most output he canhe has about 400w to each sub if that helps any.
January 8, 200917 yr Author thanks to caligreen i was told that the RE box calculator works pretty well, anyone have personal experience with it? it says i should have 33.67hz tuning w/ 4.603 cu. ft. i think that should sound pretty decent
January 8, 200917 yr you know that box is going to be like 2 times the size of the one i had my ssd in....
January 8, 200917 yr Author good i measured it out and i wll still have a seat left, a cramped seat but its still a seat
January 8, 200917 yr you know that box is going to be like 2 times the size of the one i had my ssd in....how'd your 18 turn out on the 3000d?
January 8, 200917 yr thanks to caligreen i was told that the RE box calculator works pretty well, anyone have personal experience with it? it says i should have 33.67hz tuning w/ 4.603 cu. ft. i think that should sound pretty decentI've never used it... I just do the math... that box will probably be just about right for the cvr's, they like a big box... the last cvr box I built was roughly 3.5 tuned 35... didn't sound too bad, personally I don't like the sound of the cvr's, but opinions may vary how much port are you planning??
January 8, 200917 yr Author i have the dimensions and everything written down somewhere but its going to be 4.603 cu. ft. tuned to 33.67 hz so it should be a decent improvement from my current box, i love my cvr's they are not insanely loud thats for sure but its only 400rms per sub, they have sounded good in every box i have had them in and never had any problems, and i used to clip the hell out of these subs too until i discovered how to properly tune an amp
January 8, 200917 yr Author you know that box is going to be like 2 times the size of the one i had my ssd in....how'd your 18 turn out on the 3000d?and he will probaly have a similar answer but damn does that thing bump! hits very hard but sounds clean at the same time
January 8, 200917 yr you know that box is going to be like 2 times the size of the one i had my ssd in....how'd your 18 turn out on the 3000d?the btl loves the 3000d, im just waiting til i get my truck back now from the body shop, so i can remove the back seat, and build a amp rack, run 0 gauge and also hook up a yellow top im getting. the btl sounds great in the box, i made a double baffle the other week for it, and i sealed every crevace shut. thanks again for the help!
January 9, 200917 yr Here is a box I came up with: Pretty much build the box to the dimensions you gave. 39" wide x 17" high x 17.5" deep. That gives you about 5.4 cubes. The port I came up with- 15.5"h x 3"w x 18" long, displaces .6. That leaves you with .2 cubes for driver displacement, which is close enough, to get to your 4.6 cubes net tuned to 34 hz.
January 9, 200917 yr Author thanks man, thats actually almost the exact dimensions RE audio calculator gave me and i printed the cut sheet so i guess im gonna use that design, i will put pics up when i finish, i wont start until next weekend though
January 9, 200917 yr sounds good, good luck on the build and dont forget to round off corners and seal it up nice.
January 9, 200917 yr Author thanks eric, i will seal everything up for sure, but i am doing this at my friends house so hopefully he has a router or sander to round the corners off with
