Posted January 9, 200917 yr A 2005 Nissan Sentra...I'm looking to do mid 140s with duel 12s or single 15. Spending limit is around 2500
January 9, 200917 yr btl 15 and saz-3000 with an extra battery or two and HO alternator and tons of 0 gaseriously though a budget and a db number isnt enough info to pick out a system with
January 9, 200917 yr If you build the correct box, you won't need to spend anywhere near that amount to hit "mid 140's".
January 9, 200917 yr agreed... my old box was hitting exactly 140db on olny 100w. it all depends on the box you build for the sub/subs
January 31, 200916 yr You have a good budget to work with. I would go with a 15" btl if you can fit it into your trunk with the proper box.
February 2, 200916 yr first you should tell us more info. you can get 140s with a single 12 if done right.
