Posted January 12, 200917 yr Ok, im looking to buy some comps for my carThe subs stage is a 15" fully loaded BTL and Hifonics 2600 ampThe car is a 2000 Hyundai Sonata6.5" speakers.Im thinking of doing some of the alpine type Rs in the front and keep the rears stock for a while, so what i think.when i had my 2 15" alpine type r subs, i was fine with my stock speakers, is that weird? lol
January 12, 200917 yr ive listened to the type r's and dont like them they are also not that efficient so they dont get that loud. whats your budget and what do you have to power them.
January 12, 200917 yr id reccomend you get an amp if your gonna spend money on a decent set of comps.
January 12, 200917 yr cheap and should get loud speakers and amp. the speakers are a 2ohm set of comps so you will get 100wrms x 2 out of the amp. the speakers have a sensitivity of 93db @ 1w/1m so they will be efficient. they both have free shipping so the total is less than $160 so you can get some wire and rca's.
January 13, 200917 yr Author those cadence ones look pretty sweet, the amp looks nice too,what all else do i need? like you said "wires and rcas"
January 13, 200917 yr big jons said these dont like a lot of power, but their dope cheap right now and im looking at getting a pair soon.CDT 6.5 on WooferEtc
January 13, 200917 yr pg rsd components are also a very good option. can be found for about 80 bucks.
January 13, 200917 yr Not trying to thread jack or anything.But components only need a 2 channel amp right?So if the amp puts out 2x100rms @ 2ohms would each mid and tweet be seeing 50 rms?
January 13, 200917 yr Not trying to thread jack or anything.But components only need a 2 channel amp right?So if the amp puts out 2x100rms @ 2ohms would each mid and tweet be seeing 50 rms?if the component set was, lets say, 4 ohms and the amp was 100x2 at 4 ohms it would send each side 100 watts then the cross over splits it up between the tweet and mid. how much power they really see is alittle more complicated and i cant explain it...
January 13, 200917 yr Not trying to thread jack or anything.But components only need a 2 channel amp right?So if the amp puts out 2x100rms @ 2ohms would each mid and tweet be seeing 50 rms?if the component set was, lets say, 4 ohms and the amp was 100x2 at 4 ohms it would send each side 100 watts then the cross over splits it up between the tweet and mid. how much power they really see is alittle more complicated and i cant explain it...Have to be careful with your wording here, as the crossover splits up the frequencies between the tweet and mid, not the power. Both the tweet and mid would still receive 100 watts each. This is because they aren't playing the same frequencies.
January 14, 200917 yr Author what would new speakers that arent amped compare to what i got stock in my hyundai sonata 2000?
January 15, 200917 yr Not trying to thread jack or anything.But components only need a 2 channel amp right?So if the amp puts out 2x100rms @ 2ohms would each mid and tweet be seeing 50 rms?if the component set was, lets say, 4 ohms and the amp was 100x2 at 4 ohms it would send each side 100 watts then the cross over splits it up between the tweet and mid. how much power they really see is alittle more complicated and i cant explain it...Have to be careful with your wording here, as the crossover splits up the frequencies between the tweet and mid, not the power. Both the tweet and mid would still receive 100 watts each. This is because they aren't playing the same frequencies.I'm not doubting you here, but why is that? If you hook two subs up to an amp it would split the power between the two, right? Why would it work differently with the comps?
January 15, 200917 yr Author what do i need to http://www.cadencestore.com/ProductCart/pc...p;idproduct=479run that amp? i already have 1/0 running to the trunk 1/0 ground, and the hifonics bxi2608d
January 15, 200917 yr Not trying to thread jack or anything.But components only need a 2 channel amp right?So if the amp puts out 2x100rms @ 2ohms would each mid and tweet be seeing 50 rms?if the component set was, lets say, 4 ohms and the amp was 100x2 at 4 ohms it would send each side 100 watts then the cross over splits it up between the tweet and mid. how much power they really see is alittle more complicated and i cant explain it...Have to be careful with your wording here, as the crossover splits up the frequencies between the tweet and mid, not the power. Both the tweet and mid would still receive 100 watts each. This is because they aren't playing the same frequencies.I'm not doubting you here, but why is that? If you hook two subs up to an amp it would split the power between the two, right? Why would it work differently with the comps?Because they play different frequencies, as I said. An amplifier will put out 100 watts across the whole frequency range. If you have one speaker playing 0-5khz, it will get 100 watts. Then if you have another speaker playing 5khz-20khz, it will get 100 watts. It's just like if you only had one speaker playing the whole frequency range. That's how the amp sees it, anyways. It's the same reason why they have both a 4 ohm mid and 4 ohm tweeter in the component set, but the whole system is still rated for 4 ohms, not 2. But with subs, they are playing the same stuff, so that 100 watts has to get divided into two drivers, and those individual 4 ohm subs would be 2 ohms if wired in parallel.
January 15, 200917 yr Author what do i need to http://www.cadencestore.com/ProductCart/pc...p;idproduct=479run that amp? i already have 1/0 running to the trunk 1/0 ground, and the hifonics bxi2608d Edited January 15, 200917 yr by sandsnip3r
