chitty, are you getting the same amp?
nope.
going with Autotek MM3000 & 100.4, getting it for same price as RD pretty much, straight from Maxxsonics.
can't deal with buying off the forums ATM.
  • 2 weeks later...
  • Replies 60
  • Views 9k
been a while since a update.
dont have RD anymore(never even ran it :() or the alpine.
whats going on:
order MM100.4, next week MM3000.1
RSDs, Speaker Rings(thanks Mike!) deadner(thanks noph33r!) install very soon
along with batcap 800 in the rear, traded off a batcap 2000.
install new fuse holders.
also replaced 9883 with 9855 so i can run active.
probably will start amp rack when both amps get here.
a couple new pics!(nothin major)
Alpine 9855
PG RSDs
installed
Got Speaker Rings in(thanks mike!)
Also got my Big 3 wires and Fuse Holders wired up for amps
Now just waiting on the 100.4 and grab deadner and i can start installing
Lookin' good! Keep the pics coming.
thanks :D
more pics to come later on, but i'm sure i wont have the frontstage up and running til tomm :(
minor updates. everything coming along nicely.
pics:
WIRES RAN THROUGH DOORS
DOWN INTO PANEL
WIRES RAN TO BACK
MY MIDS UPGRADE
MID INSTALLED(DIDN'T NEED SPEAKER RINGS :()
AMP RACK STARTING TO TAKE PLACE
I also ran mp3 adaptor and remote wire, no pics.
just need to run passenger side wires and then i'm done!
But still stuck on where to mount tweeters, HELP!
still got passenger side wires to run
but started on amp rack.
rack started out a certain way and had to be changed.
pics:
there is where i'm stuck at for the next few days til i can get it done.
Whoa you have changed your set up around so much..
Different amps and such.
Looking good though.
I like to try things :)
and i would have kept the RD but it arrived broken :(
but this is the final setup for some time, only thing that might change is subs(add more)
  • 2 weeks later...
