Hi I am starting my build very shortly and I have a question on making the sub box. I have made L slot port boxes before but for my 2 12" Fi SSDs I want to make the port in the middle. So the question I have is can I make it by just calculating for 1 of the subs and just build it together?
Space is not an issue.
Thanks ahead for all the input
You need to calculate the port for both subs. Otherwise the port will be grossly undersized for both subs.
yea, so if i designed a slot port box and then like mirror imaged it together it should keep the same tuning?
