Posted January 19, 200917 yr Hi guys, Question if you run one D1 subwoofer an one D2 sub on the same sub amp will one get more power to it ?
January 19, 200917 yr yes, I would not recomend it. there is no way to wire those to get the same load.
January 19, 200917 yr If you dont have the same subs dont hook them up together.I did this once and my amp got all F&%KED up. It got so hot if you touched it it would burn you... Then it died. So in short NOT A GOOD IDEA
January 19, 200917 yr I did this once and my amp got all F&%KED up. It got so hot if you touched it it would burn you... Then it died. So in short NOT A GOOD IDEAlol
January 20, 200917 yr Author I did this once and my amp got all F&%KED up. It got so hot if you touched it it would burn you... Then it died. So in short NOT A GOOD IDEAlol Thanks guys
