Posted January 21, 200917 yr I have a desired tuning frequency that I want but I will have two ports...I think.The best example I could find is in the Stealth Avalanche build, basically the same idea he did but in a different vehicle and different subs, bit more air space.Here is what it looks like.As you can see, there is a port with a partition in between. So my question is, how do I figure out what to tune too. Do I tune each port to what I want the tuning to be...do I need to do some calculating and figure it out through equations....I could use some help on this subject.Also how does this type of enclosure work since the port is firing directly in front of the subs? I would assume there is some kind of db level gain...
January 22, 200917 yr no one? guess it'll be trial and error then.That's the best way!! I'm doing that with my wall haha
January 23, 200917 yr the way it was explained to me is that for 2 ports, you tune each port to half the box. so if you have say a 10 cube box, you would tune each port to 5 cubes at whatever Hzfrom JL"Divide the chamber volume by the number of ports you wish to use for that one chamber.• Take the quotient and use that as your Vb (box volume) in the port formula• Do the number crunching and figure out how long each port should be." Edited January 23, 200917 yr by christobear
January 23, 200917 yr Author the way it was explained to me is that for 2 ports, you tune each port to half the box. so if you have say a 10 cube box, you would tune each port to 5 cubes at whatever Hzfrom JL"Divide the chamber volume by the number of ports you wish to use for that one chamber.
January 26, 200917 yr Author Update.\/\/\/okay here is my pos sketch up # 1each port has (rounded up) 85in^ of port area.each is tuned to 36 hz. <<<< am I supposed to tune each port to the total desire tuning or what??each side is 8.125ft cubed.______My port area is a bit small, I know.I would glass corners/etc. and use threaded rod for bracing. I was thinking of double baffle for the subs. this is my first mock up...I am not too happy but I will keep on.ALSO I plan on dc level 4 15's
January 27, 200917 yr Looks very interesting, i know little about clamshells or the benefits they offer but they seem kinda like hybrid horns that you see in PA cabsIm looking forward to seeing a build log, and that picture is sick
January 28, 200917 yr Author #2 here.6.73ft cubed each side, 6.93 before guesstimated displacement.99in^ of port area for each side, total of 198in^effective port length is 24.5in so Ill just say 24in.tuned to 35 hertz, actually 35 point something.questions & comments?
January 31, 200916 yr #2 here.6.73ft cubed each side, 6.93 before guesstimated displacement.99in^ of port area for each side, total of 198in^effective port length is 24.5in so Ill just say 24in.tuned to 35 hertz, actually 35 point something.questions & comments?those look pretty friggin' cool to me!what are you planning on putting it in? I'm thinking of something similar using (2) 10's in a center console, with the port firing across the subs, maybe acoustically coupling the output of the front and back wave???
February 3, 200916 yr Author here is mock up #3 it is very much like supergumby's. I followed his advice on taking the subs "out of the port." this gave me less air space but the subs will still be getting enough and each chamber is tuned to 32 hertz with 79in^ of port area. it is more a true clam shell now. I really like this design. again it will all be braced with threaded rod and fiberglass.questions & comments.edit: after doing some other measurements, tuning maybe actually be around 30 hz. anyways its very low 30's
February 4, 200916 yr This is for a ranger, right? If so I'll be watching this very closely. I'm wanting to try a blowthrough this summer...good luck man.
February 5, 200916 yr Author I believe #3 will be my enclosure. I'm going to call my conect. and purchase soon.
February 6, 200916 yr Author Chuck, have a look-see at mock up three. I almost certain this is what I want to build.
