Posted January 22, 200917 yr What would be the best way to wire into the box. Best as in the most secure, and most current flow.A friend of mine just drilled holes and fed the wire through, then just siliconed around to seal it up. I have also heard of people driving bolts through and wiring to them. If this will work, what type/metal bolt would be best.My last setup used actual terminals that I got from Sound Advice. I siliconed the back of them in, but not sure if they were secure enough.All advice is appreciated.
January 22, 200917 yr If your going to do bolts ( i am also) i would use copper bolts and washers if you can find them or brass.
January 22, 200917 yr I do the wire straight through with caulk method. I don't like those little black plastic round or square terminals very much, they usually use those cheap spade connectors on the inside, and can leak air around/through them.
