Posted January 30, 200917 yr I was needing some opinions on what kind of enclosure I should buy considering I'm not a carpenter I'm looking to purchase 2 RE SE12 Subs w/Hifonics Bxi1606d amp.. I'm going to put this Bumping machine in a 1993 Nissan Pickup D21 extended cab got a credit card so that would be affordable with tax returns coming around.. All opinions welcome
January 30, 200917 yr Author I'm going to message you.. you had the system that I want now do you care if I pm you?
January 31, 200917 yr If you're wanting to go for SQ you're going to want to have a sealed box. Are you going to build your own box, or have someone build one for you?
January 31, 200917 yr Author already purchased a sealed box. My System:1 x Hifonics BXi 1208D 1200W RMS Mono Block Class D 1 Ohm Stable Brutus Amp (BXi1208D)(2) RE Audio SE12 D4 SubwoofersDual Enclosure it will work.. I told the guy what i was gonna use he told me to purchase this one..SQ212 - Ground Shaker 12" Dual Sealed Box All I need to now is to figure out what kinda amp wiring kit im gonn use?
January 31, 200917 yr Author it will be also Sealed Enclosure if that wont bump then Ill go to vented
February 1, 200917 yr depends on ur taste of how loud since my pair of 10s does 140 on a termlab meter with only 1200wrms , the sq is very nice & its enough for me for daily use
