Posted February 2, 200916 yr I am getting 2 15" AA havocs (hence the name lmao!) 1250 watts rms per sub ... i have noticed that they are going to have to be dvc 2 ohm per sub (no other options for ohms)... My question is which amp would be better to power these subs... i kno alot of responses will be sundown... and i am leaning toward sundown but thinking realistically i could wire the sundown to 2 ohms and get 1600 watts split between 2 subs or i could go with the kicker and get 2500 split between subs... i really want the sundown but i dont want to underpower the subs... i am stuck and getting indecisive... which would be the better buy...
February 2, 200916 yr You could always wire the amp down to 5Ω. But, I don't know if those subs can handle it...Never really looked into them.
February 2, 200916 yr Well since your final ohm load will be 2 ohm and you can't change it then go with the kicker.I am runnin an 08 Kicker zx2500.1 for 2 12" Fi SSDs and I love the amp, Kicker amps have never failed me.
February 2, 200916 yr if you really want a sundown amp you could go with 2 saz1500s, but i havent heard anything bad from kicker amps.
February 2, 200916 yr Author Oh i didnt kno that AA manufactured them in one ohm ... I got another questionIs there any other good audio companies that manufacture amps rated at 2500 watts rms @ 2 ohms?
