Posted February 3, 200917 yr So whats the best head unit i can get for around $120 that fit an E,S,U.Going in a 1993 Range Rover County.
February 3, 200917 yr Author Thinking about thisKenwood KDC-MP242Is this really needed? -> http://www.crutchfield.com/p_127OEM2/PAC-OEM-2.html?tp=3486 Edited February 3, 200917 yr by Dutchie.
February 3, 200917 yr Looks like any way you go about it, you're custom mounting and wiring it. There aren't kits available pre made.
February 3, 200917 yr Author Looks like any way you go about it, you're custom mounting and wiring it. There aren't kits available pre made.According to crutchfield i won't need a kit, and if wiring is needed, the dash might be pulled apart to replace the heater core*, so i'll rewire then. Edited February 3, 200917 yr by Dutchie.
February 4, 200917 yr they make a single din dash kit, that is not for reducing the size of dash... but to allow the deck to be adjusted out for shallow dashs.
