Posted February 2, 200917 yr Ok i need to know which one of these amps are the better one to get (am running a 1 ohm load). I narrowed it down to either the Autotek MM 2000, the Soundstream PCX2000D or the Soundstream TRX2000D. I would like to hear from anyone who heard these amps. And which one of these amps do rated power or is closes to rated power. Any input? Edited February 2, 200917 yr by wof131s
February 2, 200917 yr Author Ok i need to know which one of these amps are the better one to get for 2 Fi Q's (am running a 1 ohm load). I narrowed it down to either the Autotek MM 2000, the Soundstream PCX2000D or the Soundstream TRX2000D. Which of these amps do rated power or is closes to rated power. Any input?
February 2, 200917 yr More than likely these amps are probably pretty much the same amp. Using the same boards with the same internals with maybe a few different parts to them.
February 2, 200917 yr Ummm....Double post, might want to combine your two posts. Give us a budget range on amp.
February 2, 200917 yr Author Am just wanting to know which one of those amps would go better with those subs. Any other input?
February 4, 200917 yr Author AQ2200D or US Amps MD.3D? Just want to know which amp will be the best for 2 Fi Q 15's w/o BP power? Help please Edited February 4, 200917 yr by wof131s
February 4, 200917 yr How many threads are you going to make on this same topic?I'm merging all of them.
February 5, 200916 yr The Audioque amps are very nice I am currently running two of the 3500 amps and they are great. You can purchase them direct for www.audioque.com
February 28, 200916 yr Does anyone know what is the AQ2200D amp rated at with a 2ohm load?The AQ2200D will give you 1300 plus at 2 ohm
