Posted February 6, 200916 yr I have now havoc 15" in 3CF sealed box running on saz1500d. I have 2001 626 mazda.Can someone please help me to build the loudest box for my system ?
February 6, 200916 yr I assume you want to build a ported box to replace the sealed one?Can you post up the maximum dimensions the box can be?Brian
February 6, 200916 yr As said post up some max dimensions and we can steer you in the right direction.
February 6, 200916 yr make the box a little bigger put a massive port in it and then tune it to a moderate level
February 6, 200916 yr make the box a little bigger put a massive port in it and then tune it to a moderate levelNice. . .do you build a lot of boxes?
February 6, 200916 yr Something like 4.5 cubes, with around 55-60in^ of port tuned low, to like 30hz would be awesome if you're into alot of rap with low bass.
February 7, 200916 yr Author I can go up to 100*55*40.I like low bass but i'm afraid to lose all the accuracy by porting.
February 7, 200916 yr Author I forgot to mention its not inches but centimeters (Israel).I've heard people running single havoc with 1800+ watts daily and I want to know which is the right enclosure to run it that loud ?
February 8, 200916 yr With 1,800rms daily you will want a smaller enclosure, and go a little smaller than normal on the port area. Will give the sub alot of help in taking that kind of power daily.
February 8, 200916 yr Just finish a box for a Havoc 15"... 4.5 net tuned to 28 htz. I loooooove it.40 x 21 x 15 inches. Approx. Edited February 8, 200916 yr by nick_19
February 10, 200916 yr Author so what should I do for maximum loud ? 4.5 or smaller ? which size of port ? does it matter if its rounded or long squared ?
