Posted February 7, 200917 yr having trouble with engine noise plz help if anyone knows the problem.. everything is wired correctly
February 7, 200917 yr Hmmm...What kind of HU do you have?Did you run your power wire & RCAs on opposite sides?
February 7, 200917 yr Author its my friends setup its an older pioneer low volts and yes theyre split on opposing sides
February 7, 200917 yr its my friends setup its an older pioneer low volts and yes theyre split on opposing sidestry grounding out the RCAs on the back of the HU. There's tutorials everywhere & probably on this site.
