Posted February 8, 200917 yr alrite ive got a set of the image dynamics idq 31 eq's and if anyone has ever dealt with these they probably know how to help me. the back of them has all liek XLR input and output jacks, except for 1 rca input and 1 rca output. the way i have had them hooked up for the past year (and yes i kno this is horibly wrong and totally killed my stereo imaging) is had the front l+r into a y cable and in to the eq then out and split it back into a l+r rca. and same with the back. It bugged the hell outta me and i do not want to run it like this so i was wondering if anyone can give me any input on all of the other jacks on the back or if anyone has any of the plugs or anything. otherwise after my rebuild i will probably just disconnect these and leave them in for cosmetics lol but its a shame to not use these..
February 8, 200917 yr I don't know about what they do on that particular processor, but you can get RCA to XLR adapters. I've gotten some at partsexpress.com.
February 8, 200917 yr Iirc these are mono eq's, 1 for left and 1 for right. So it should have 1 rca in and 1 out for each channel. 31 band 1/3 octave mono eq's. Route the outputs to your right and left inputs on your crossover.
February 8, 200917 yr Author Iirc these are mono eq's, 1 for left and 1 for right. So it should have 1 rca in and 1 out for each channel. 31 band 1/3 octave mono eq's. Route the outputs to your right and left inputs on your crossover.i understand that they are for left and right but i dont even understand y they would just make them mono like that. becasue what about the rear channel? are they just not meant to be used on a 4 ch set up at all?
