Posted February 17, 200916 yr hello, just needs some inputs on the best possible tweeter + mid for $500 or less. also intallation will be pillars/dash@What music do i prefer?music would be all kinds, simply depends on my mood. rap, rock, lovesongs etc.@What sound do i prefer?something smooth, detailed, with an airy treble, something that you could hardly tell that theres a speaker when position properly. neutral to warm side of things.@Do i have a midwoofer?yes, i have already, but still thinking of a mid that can go down to 150-200hz
February 17, 200916 yr Take a look here for some options and opinions : http://www.zaphaudio.com/smalltest/What kind of processing do you have ?
February 17, 200916 yr Author thanks alot adrian, well for processing, still not enough for a H701, and might simply use a 9887 for now with an external active xover...
February 17, 200916 yr thanks alot adrian, well for processing, still not enough for a H701, and might simply use a 9887 for now with an external active xover...correct me if i'm wrong, but wouldn't you buy the 9887 to run active and thus eliminating the need for an external or passive crossover....
February 17, 200916 yr Author thanks alot adrian, well for processing, still not enough for a H701, and might simply use a 9887 for now with an external active xover...correct me if i'm wrong, but wouldn't you buy the 9887 to run active and thus eliminating the need for an external or passive crossover....well thats true, for a full 3way system, 2way fronts with a sub or 3way fronts w/o sub... ill be doing a full 3way front and a sub, technically a 4way setup. Edited February 18, 200916 yr by zitric
