Posted February 17, 200917 yr What would be a good audio system... i had a set up in mind but i think im going to scratch what i had in mind cuz it was out of my price range i want somethin that has good SQ and is a good daily driver but when im with my friends and want to show off i can turn it up and make it hard for them to breath... also im kinda tight with money so i can work with up to $1000 going into the trink of my car im lookin for 2 15's i listen to everything but mostly rap & r&b and bass tracks... anyone has a good Sub/Amp combo for $1000 if its 1100 or 1200 thats fine too
February 17, 200917 yr your question is pretty vague, if you try to elaborate a little more following the criterion in these threads you will get a more/faster/better replies. as it sits now, if you're on a budget and want a ground pounder i'd go with four mach-5 mj-18's and a gp3000d personally. http://www.soundsolutionsaudio.com/forum/i...showtopic=13994http://www.soundsolutionsaudio.com/forum/i...showtopic=22849
February 19, 200917 yr Author Well i had the SSA Icons in mind as well as the AA Havocs and the Fi Q's ive heard that they had pretty good sq for their price... now do these subs get loud like hair trick loud when i wanna show off or are they more for jus daily drivers and not so much spl...another question is if i were to get one of these brands and go 2 15's would a ported box be able to hit all the notes in the desired rap music hz range, i understand some notes are going to be louder than others but if theres a particular note will the subs sound like it has a dead spot if i tune the box correctly or will it sound like a sealed box where it hits all the notes without a dead sounding spot... opinions appreciated greatly... remember im still kind of a noob to the specific terms for things so kinda dumb it down... go easy on me...
February 19, 200917 yr A little above yourt budget, but 4 SSD 12 or 15s on a Crunch GP3000 would be sweet.2 Q 18s on a Hifonics Brutus 2608 would be sweet and well within your price range as well.
