Posted February 20, 200917 yr How could I brace my port more, or do you think it needs to be braced?Here is the bracing of the entire box, but it is also for an idea of what the port looks like...also, do you think a 45 would be helpful in my port? I don't think it would make much of a difference.... Edited February 20, 200917 yr by rumproast789
February 20, 200917 yr From what I'm seeing it looks to be fine. Add a 45 if you can. Won't hurt anything!
February 20, 200917 yr Author From what I'm seeing it looks to be fine. Add a 45 if you can. Won't hurt anything!Thanks! I was really hoping for an answer like that!How do I know how big the 45 should be? I'm thinkin real small...
February 20, 200917 yr From what I'm seeing it looks to be fine. Add a 45 if you can. Won't hurt anything!Thanks! I was really hoping for an answer like that!How do I know how big the 45 should be? I'm thinkin real small...Make it's the same height as your internal height and I wouldn't go any smaller than 2" wide. Somebody might have a better answer for you on the width. Not sure if there is any set formula to calculate 45 width.
February 20, 200917 yr Author From what I'm seeing it looks to be fine. Add a 45 if you can. Won't hurt anything!Thanks! I was really hoping for an answer like that!How do I know how big the 45 should be? I'm thinkin real small...Make it's the same height as your internal height and I wouldn't go any smaller than 2" wide. Somebody might have a better answer for you on the width. Not sure if there is any set formula to calculate 45 width.I'll see what I can come up withthanks man!
