Posted February 21, 200917 yr Hi EveryoneNeed Advice On How To Make My Box Look Good.I Want A Quick Project Do Do Under $60Carpeting,Paint,Stencil, Spray On Bedliner ?Let Me Know If You Have Any Ideas.Here is A Pic Of The Box.Thanks ~ Kent ~
February 21, 200917 yr i always liked the look of steve meades boxes...the textured type of paint, just seal up all cracks and screws with some type of bonder or w/e and do that.
February 21, 200917 yr http://www.duplicolor.com/products/metallic.htmlthis would also look just as nice and really easy to use.
February 21, 200917 yr I used flek paint from walmart about 4 dollars a can I used 3 after sanding and rounding off the corners. matches my seats pretty well and is durable.Chad
February 21, 200917 yr Author Thanx Guys Im GOing To Run up To Walmart And See What Kind Of Textured Spraypaint They Have.Also Im Gonna Go To The Arts And Craft Section And See If I Can Buy Some Foam To Make Some 3d Logo Pop Out Stencil So I Can Make A Logo Of FI Car Audio To Put On My Box And More Ideas Are Certainly Welcome
February 21, 200917 yr Author Alright Everyone.I Just Went Up To The Local Hardware Store And Got Some Stuff.Need Some Ideas And Pics Of How I Should Paint My Box.Port Area White And Box Black ?Or What Do Yall Think ?ThanxPics Would Be Nice Even If There Not Same ColorsI Just Need Some Ideas. Thanx Again
February 21, 200917 yr Author Anyone.....I Need SOme Ideas Fast Cuz Im Getting Ready To Finish It So I Can Show Yall And Provide Pics
February 22, 200917 yr Author Ok so i was looking at my box and an idea came to me. First off i wanted to put a Plexiglas on the top of the box so you can see the inside. Something along the lines of 17"X13". I would have to use several sheets so it could come out to a thickness of approx 1/2 because i don't want it to flex. Next i would paint the inside white and put a black light in there so everything would glow and paint the outside black like i had originally planned. One question though.....Will the florescent black light be able to survive inside the box??Let me know your opinions and ideas-Kent
February 22, 200917 yr i wouldnt layer plexi to get your thicknes might make a slapping noise. neons might work but if you can get leds go that route.
February 22, 200917 yr Author Will just one layer of Plexiglas glass work? The only one i could find at my home depot was about an 1/8 of an inch thick and I'm concerned it might flex. Do they make it in different thicknesses?-Kent
February 22, 200917 yr Will just one layer of Plexiglas glass work? The only one i could find at my home depot was about an 1/8 of an inch thick and I'm concerned it might flex. Do they make it in different thicknesses?Order online. I don't have any recommended vendors, but a quick Google for "plexiglass" led me to this.
February 22, 200917 yr Author Where are you located? I might be able to help you out.Im located in Katy Texas. Do you have some plexiglass? I was thinking of enbeding out a design or something so that the letters will glow when there presented to light. Something like this.....
February 22, 200917 yr you should try to get some 1/2in lexan over plexiglass although it cost more but is more durable and will withstand more abuse
February 22, 200917 yr Where are you located? I might be able to help you out.Im located in Katy Texas. Do you have some plexiglass? I was thinking of enbeding out a design or something so that the letters will glow when there presented to light. Something like this.....I have some 1/2 lexan, but not the exact size you are looking for. If interested pm me.
February 22, 200917 yr Author Thanx For The Offer But I Just Ordered Some 3/4 In Plexi.Ill Keep Everyone Posted With Pics Of The Build
February 22, 200917 yr Author Well i got the front baffle made and i ordered a sheet of 3/4 inch Plexiglas. Sanded the big guy down real good and rounded down all the corners. I painted the inside white but it doesnt glow under the black light like I had originally planned. Guess I'm going to head up to the local hobby lobby and see if they have any florescent paint.Heres some pics of todays progress-
