Posted February 22, 200917 yr I was told by a former "audio guy" that althought 3/4 MDF is used in car audio enclousers, 3/4 partical board could be used to reduce the weight of the encloser. How tru is this?
February 22, 200917 yr yes you can. you have to be very careful because it tends to fall apart on the edges. but it can work in a pinch.Chad
February 22, 200917 yr Just use good stuff that's void-free. I used baltic birch plywood on my last box and it's awesome. So light.
February 24, 200917 yr Author Ok, thanks guys that helps a hold lot. Now is there anywhere that i can get some cheaper 1/0 gauge wire. The best i found was $6.45 a feet. Any help here?
February 24, 200917 yr x2 on the Birch. Particle board is not very tolerant to any sort of moisture. Me being in Fla, particle board will fall apart just with the moisture in the air. I'm making my enclosure with birch plywood and it is extremely light and easy to work with.
February 25, 200917 yr i just bought some 1/0 from knukonceptz.com its 1.75$ per foot and they stuff the chit out of it with wire.....shipping was also quick too.
February 25, 200917 yr i just bought some 1/0 from knukonceptz.com its 1.75$ per foot and they stuff the chit out of it with wire.....shipping was also quick too.Knu does have cheap 1/0, but it's cheap for a reason. They have different qualities of 1/0.
February 25, 200917 yr i just bought some 1/0 from knukonceptz.com its 1.75$ per foot and they stuff the chit out of it with wire.....shipping was also quick too.Knu does have cheap 1/0, but it's cheap for a reason. They have different qualities of 1/0.i agree, the knu i've seen really cheap is alu core. if you want pure copper just get weldingsupply.com or weldingdepot.com cable.
February 25, 200917 yr www.knukoncepts.comx2I never had good luck using partical board. It was flimsy around the edge and the glue doesnt hold up nearly as good as mdf or even better is baltic birch or Trupan light (not sure where to get it)
