Posted February 23, 200916 yr If am using a 2200 watts rms amp (does rated power), will there be a big difference if i use 2 gage wire instead of 0/1 gage wire for the big 3?
February 23, 200916 yr It's an upgrade from factory wiring, but if you rip it out later just to do 0/1 than you really didn't save any money in the process.
February 23, 200916 yr Author Am not ripping out the factory wiring, am just wanting to know if using 2 gage instead of 0/1 would be any less effective?
February 23, 200916 yr It will be fine. remember your not replacing wire, your adding to the existing wire.
February 25, 200916 yr It will be fine. remember your not replacing wire, your adding to the existing wire.You can replace them if you do it right (sand to bare metal!). My damn grounds look like 16 AWG speaker wire. Yay for 1/0.
