March 8, 200917 yr Internal bracing will do A LOT more good than doubling everything.depending on the install. I do double baffle so that the box won't flex and try to fall apart making it stronger. Bracing helps but double baffling is necessary depending on what your building. For this one i would do it
March 8, 200917 yr Internal bracing will do A LOT more good than doubling everything.depending on the install. I do double baffle so that the box won't flex and try to fall apart making it stronger. Bracing helps but double baffling is necessary depending on what your building. For this one i would do itMost double baffles are to keep the sub(s) from ripping out of the box.
March 8, 200917 yr Author if i feel the need to double everything up after the initial testing, then i sure will do. even if i gotta do it the morning before i leave for Daytona.
March 8, 200917 yr Internal bracing will do A LOT more good than doubling everything.depending on the install. I do double baffle so that the box won't flex and try to fall apart making it stronger. Bracing helps but double baffling is necessary depending on what your building. For this one i would do itMost double baffles are to keep the sub(s) from ripping out of the box.no you do it so the pressure from the subs don't destroy it. If you got alot of power etc you wanna do it. I have seen alot of boxes flex due to not double baffling it( everything sides, bottom top). Like i said, some people need to do it, some don't. 1inch mdf will work to Edited March 8, 200917 yr by bigt
March 8, 200917 yr Author all in all this set-up is probably gonna get taken out soon depending on how much i like the sound.i know what not to do now when building a wall so the next one should be plenty better. all in all though, im gonna have a port braced with 2x4's as well as like 6 braces inside the box from various other points. if this thing flexxes id be quite surprised.
March 8, 200917 yr Internal bracing will do A LOT more good than doubling everything.depending on the install. I do double baffle so that the box won't flex and try to fall apart making it stronger. Bracing helps but double baffling is necessary depending on what your building. For this one i would do itMost double baffles are to keep the sub(s) from ripping out of the box.no you do it so the pressure from the subs don't destroy it. If you got alot of power etc you wanna do it. I have seen alot of boxes flex due to not double baffling it( everything sides, bottom top). Like i said, some people need to do it, some don't. 1inch mdf will work toAn extra layer of wood wont add nearly as much strength than some good cross-bracing.
March 8, 200917 yr whatever.....just giving my opinion. no matter what you use for bracing, it will flex
March 8, 200917 yr plan was for 3 18's but i accidentally cut my baffle to short :rollseyes: so i just decided to go with 2.Power will come from either a US Amps XT4000D @ 2 ohms, or 2 DD M80's Strapped @ 2 ohms.has 225 amp alt and 1/0 big three. and big 3 throughout the truck.going to switch subs out if i dont like them to much for something else ... we'll see what the ones i got on the way do Aren't you using the Z1 ?
March 8, 200917 yr plan was for 3 18's but i accidentally cut my baffle to short :rollseyes: so i just decided to go with 2.Power will come from either a US Amps XT4000D @ 2 ohms, or 2 DD M80's Strapped @ 2 ohms.has 225 amp alt and 1/0 big three. and big 3 throughout the truck.going to switch subs out if i dont like them to much for something else ... we'll see what the ones i got on the way do Aren't you using the Z1 ? My thoughts exactly , thats a sexy amp !
March 8, 200917 yr Author i sold the Z1 ALONG TIME AGOi wish i wouldve never sold it now. how i miss it.ill have a Z2LV soon though. as well as some 22" BTL's or Level 5 18's. whichever i decide to do.
March 10, 200917 yr I got a comment for you. But you got to PM me to tell me you are online to get it
March 11, 200917 yr Author gonna glass the port brace in, the seams of the port and screw the back piece to the back wall then hope to work on the beauty panel before sbn ..... running outta time though cause i gotta be a ported box for 3 12's tomorrow as well :BULLchit:
March 11, 200917 yr Oh yeahhhhhhOne person to let them know. Then I'm locking the membership applications for a while.
March 11, 200917 yr Author well, everything is up and running.i think i have to much port, and i DO have box flex on the back piece. not to big of a deal. Rebuild coming soon.pics anyone? Edited March 11, 200917 yr by dwright27
March 12, 200917 yr Author Team Bad Companyand a short vid.Like i said, home depot didnt have any whole sheets so i spliced one for the back wall. got another few braces to put in if i have time short vid.ill take some decent daytime vids tomorrow. got a bit of windshield flex Even though im tuned at 35 it KILLS the lows.
