Posted March 24, 200916 yr yesterday out of the blue my car door started popping while I open it, not as bad when i shut it. in front the body seam is right up against the door seam, so the door is sitting forward... pushed/bent toward the front of the car.The rear seam is now a big gap.I checked the hinges, they dont look bent or like they have any play.top hingebottom hingesorry this camera blowsI tried lifting the end of the door, there is no play, and visually the black rubber/plastic bushings look OK... bolts tight....
March 24, 200916 yr looks like you pushed the door open to hard, one to many times. you usually see that when people have there door open in a parking lot and someone hits the door a little, or someone has there door open and backs up into something with there door.the frame is probably bent a little where the hinges connect. Edited March 24, 200916 yr by าชกุศล
March 24, 200916 yr Author I compared it to the other side to see if there was a gap between the hinge and where it mounts, but both sides look the same, and when I open both doors all the way, they seem to go the same
