Posted March 24, 200917 yr Will be using them for SPL competitions in IASCA.. will post my scores here..Power - 2 Sundown SAZ1500DsBatteries - 1 Powermaster D2400 up front and a D3100 at backPowermaster 140A alternatorHeadunit - Pioneer 6000UBPreamp - Soundstream 6XOAudiocontrol 6XS Crossoversome hott dust caps!stitched tinsel leads, nice!the score to beat is 150.5dBs on the termlab (151.6dB AC) i made using a pair of Audiopipe TXX 15"s name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>"> name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350">
April 6, 200917 yr Author i came 3rd in my 1st competition with them yesterday with a score of 150.1dBs.. the box used was poorly tuned and installed last minute for the competition.. no testing was ever done..Advance 2 1st Ronald Suhkbir 154.8 2nd Mohan Ramlochan 152.1 3rd Rene Roberts 150.1 4th Shameer Baksh 150 5th Adrian Boodoo 147.8the 1st place score was made by a walled off Mazda 323 hatch-back, running a 7000W Cactus Sounds amp and 2 15" Cactus sounds subs..2nd place was made by 2 95series 15" Digital Designs subs powered by a pair of 5000W Atomic amps!my personal goal is to beat those DDs
April 7, 200917 yr Those things are so sexy. I can't to get mine. I am only getting one with 1000 watts to it, but I am sure I will be impressed.
April 8, 200917 yr Author these are my boxes..some simple ported enclosures.. i'm looking for a 152 for the next show..
April 8, 200917 yr Author thoe boxes were made for my previous Audiopipe subs, so they are not really a match for the DCs..they are 5 cubic feet each currently tuned around 46Hz! 3 - 5 layers of fiberglass & resin on the inside and a coat of resin on the outside to prevent the mdf from absorbing water.. double 3/4" mdf baffle.i have to bring that tuning down to about 40Hz so it would better work in my vehicle.. when i lower the tuning, then i'll make some vids..
April 9, 200917 yr wow rene ... i have high expectations , cus i know you know your stuff... will you be ready for the show in may?
April 26, 200917 yr Author i lowered the tuning freq to about 40Hz (net volume dropped to 4.1cu.ft) and just hit a 151.6 on the Audio Control meter this evening..i believe another 0.5dB is possible with these boxes..question, what's the best score you guys have seen made with around ~3200Wrms.. my personal goal is 152dB but i not sure if that is high or low for my power..
May 26, 200917 yr I did 152.2 with 2.2k and four 12inch jl aduio w3beforeAnd 155 with 4.4 k with four of these 15 lv4.So i'd say your score is every good
May 26, 200917 yr Author you scores are very impressive as well!152.2 with 4 W3's on only 2200W.. nice!
June 29, 200916 yr Author boxes are 4.1cu.ft each tuned around 35Hz..power comes from a pair of Sundown SAZ1500D amps at 0.5ohms each..My front stage is a pretty quiet pair of CDT components, they get drowned out quite easily...
