Posted March 27, 200917 yr Ok, so I just received and hooked up my saz3000d and everything went smooth. It is a very powerful amp. However, I am having one issue. While the truck is NOT running and my head unit is paused, or the av source is off (it is a avic-n4 nav) so the hu itself is still on, and so is the amp. There is a low humming sound coming from my subs. Something else I notice is when I touch the amp it either goes completely away or almost does. Can anyone shed any light on this for me please. More info you may want:I have quality rca jacks no where close to any other wires. I relocated my ground with no change.I have a memphis eq. Edited March 27, 200917 yr by southside
March 27, 200917 yr Author Oh and also, the hum last for about 10 seconds every time. Then is stops completely for about 5 seconds, and the loop continues.
March 27, 200917 yr are you touching your amp and your car when it stops humming? if so id say its the ground
March 27, 200917 yr Author are you touching your amp and your car when it stops humming? if so id say its the groundwell, yes and no. I am in the seat but only touching fabric, no metal.
March 27, 200917 yr It's some kind of static energy. You're discharging it by touching the metal.Have you completed the big 3 under the hood and made sure the under hood grounds are attached to clean, bare metal?
March 27, 200917 yr Author It's some kind of static energy. You're discharging it by touching the metal.Have you completed the big 3 under the hood and made sure the under hood grounds are attached to clean, bare metal?I have done the big three with 0 gauge. Scraped away all paint on every ground connection. My ends are soldered.
March 27, 200917 yr rereading this. your headunit is on, its paused. is it auxilary or a cd or radio playin(before it was paused). it might be the aux cord if your using that when the noise is there. if not that, then maybe the rcas. i had some broken rcas once and tryed to strip and reconnect them. that added a humming noiseso maybe redoing the ground on the headunit or even grounding the rcas
March 27, 200917 yr Author rereading this. your headunit is on, its paused. is it auxilary or a cd or radio playin(before it was paused). it might be the aux cord if your using that when the noise is there. if not that, then maybe the rcas. i had some broken rcas once and tryed to strip and reconnect them. that added a humming noiseso maybe redoing the ground on the headunit or even grounding the rcasThe rcas are fairly new, but I think that they may be the problem. I will try it tomorrow. When paused it is running aux but it does it even when the av source is off without the aux being connected.
March 27, 200917 yr Author Ok guys I have the problem solved. I want to thank everyone for their help. To my surprise the problem was the RCAs which was strange to me because they were new and expensive with a huge jacket meant to keep interference out. Grounding them didn't help. But I put in some different ones and the noise is gone.
March 27, 200917 yr I get by fine with my 3 dollar parts express rcas, high dollar rcas are overrated.
March 28, 200917 yr I know you said you found the issue.. but thought I'd add..***this may not be fact but is what I understandit's normal.. All the saz's humm at idle--I was concerened about mine as well. I didn't talk to jake on it but the other competitors said theirs did the same thing... -the amp itself-- it's not normal if it's coming through the woofers. they gave a good reason for it but I don't recall what that reason was Edited March 28, 200917 yr by rushnrun
March 28, 200917 yr Author I know you said you found the issue.. but thought I'd add..***this may not be fact but is what I understandit's normal.. All the saz's humm at idle--I was concerened about mine as well. I didn't talk to jake on it but the other competitors said theirs did the same thing... -the amp itself-- it's not normal if it's coming through the woofers. they gave a good reason for it but I don't recall what that reason was Thanks man but it was coming through the subs.
