Posted March 28, 200916 yr Well I've been designing my box for my 2003 ext cab s10. I've decided to do the sub at a 45 degree angle facing the windshield and do the port the same way. The box is 6 ft^3 after all displacements and the port is 80 in^2 tuned to 30 hz so its about 32in long. The port is angles 45 degree off of the baffle board and goes straight down and makes a 90 degree turn and goes across the bottom. Does it have to be angled the same in the bottom of the box like its pictured below? Is that how you would do it?
March 28, 200916 yr I don't think it'll perform how you predict. The air will just try to take the shortest path out, so I think it'll jump catty-corner from the inside to the bottom of the outside. I think you could get it to work eventually, but it would involve a lot of building, testing for the tuning frequency created, adjusting the port, testing for tune, adjusting, etc.I would probably either use round ports on that angled face and bend them inside or put a slot port in the lower right corner of the vertical face on the bottom, then make it L along the back of the box. or put the port on the top horizontal part in the back. I understand you wanting to try something different, I'm just not sure it's practical.
March 28, 200916 yr I believe if you have an angle on 1 side, you add the top length+ bottom length /2 and use the average.... measuring down the center should be the sameI think you would 1/2 the length of where the angle begins... if the short side is 10" and the long side is 12" then 11" port lengthbut, if you "make up for it" by making the oppsoite end do the opposite, you have to account for both ends... take off double Edited March 28, 200916 yr by kryptonitewhite
March 28, 200916 yr Author ok thanks for all of your advice. glad i thought id ask before starting my build. well here is a revision of the box. does everything look good now or what would you change if it was yours?
March 28, 200916 yr I wouldn't have the port opening at the top of the L on the inside of the box, I'd make it vertical.
March 28, 200916 yr why not go with aero ports out the side?http://www.soundsolutionsaudio.com/forum/i...showtopic=26631but Bj did one how you kinda want to do it. he knows what he is doing.
