Posted March 30, 200916 yr Was wondering if anyone on here could offer me a reaonable design for a btl 18 for free. I have a guy at the car audio forums that has always done mine for a small fee (they are reasonable). BTL 18Tuned to ~30 hz.~ 5-6 feet ^3 48 inches wide... and max of 24 inches high.
March 31, 200916 yr My design is about what your looking for , I am also going to be running a 18" BTL . My goal was 6ft^3 with all displacement's tuned at 30Hz , slot port . Sub up on top and port back . Box is designed to fit in my hatchback car so if the dimension's don't work with your space then it can be modified . Outside dimension's 17" H x 29" W x 34" D . Using .75" MDF I get an internal volume of 8.02ft^3 . Slot port of 5.5" W x 15.5" H = 85.25sq in port area Total port length is 32.75" , port board going into the box is 23", plus the .75" MDF face = 23.75" board length . Without the sub displacement this box is 6.39ft^3 tuned to 29.83Hz . With the sub the box is 6.13ft^ tuned to 30.47Hz . The top would be double baffled making the overall outside height 17.75" . The extra bit of volume provided by the sub cut opening with 2 baffle's of 1.5" H and 16.750" sub cut diameter make's the boxe's final volume ~ 6.15ft^3 tuned to 30Hz , 85.25sq in port area (13.87sq in per cuft )The total port length to slot port internal width ratio is 5.95:1 . Cut Sheet and assemble in this order ~ Bottom - 29" W x 34" DBack - 15.5" H x 29" WLeft side - 15.5" H x 33.25" D ( port side )Right side - 15.5" H x 32.5" D Front - 15.5" H x 22.75" WPort - 15.5" H x 23" D Top - 29" W x 34" D ( need 2 of these with a 16.750" sub cut on both ) I am going to be adding some internal bracing with wooded dowel rods bracing the front to back , side to side , top to bottom , side to the port etc .
April 3, 200916 yr Yeah. Just put like .0 or something. You can change the width of it. Let me know what you end up at.
April 3, 200916 yr Author Box Width : 48 inchesBox Height : 15 inchesDepth : 20 inchesWood Thickness is 1/2 inch I believe.... I'm not at the shopPort Width : 5 inchesPort Length 2 : 6 inches Will this work with the sub up mounted on the far right of the box?
April 3, 200916 yr you definatley need the wood thickness for a BTL to be ateast .75 or even an inhc along with bracing and baffles.
April 3, 200916 yr Author I am fairly sure it is 3/4..... my memory fails me. I have no idea why I would buy 1/2. It would be braced very nicely. Therefore height gets bumped up to 16 inches. Edited April 3, 200916 yr by holley2346
April 3, 200916 yr Um, I would go with two layers of the 1/2" if I was you. So one inch total. Might need to reevaluate your plans.Edit: Nevermind. If its 3/4 with the 16" height should work great. Right at 30Hz. Just under 6ft^3 after displacement. Aint nothin to it but to do it now. Edited April 3, 200916 yr by indytrucks
April 3, 200916 yr Author The wood has already been purchased...... 3/4 inch mdf. Everyone dissed my 5/8 particle board box for 2 18 inch bl's, and after taking it out last week I noticed it had not cracked, come apart, or shown any signs of stress at all! At least if it blows apart I can show you an awesome box exploding video. But will that work correctly if I mount the sub up on the fa right of the box? Thanks edit: alright, going to start on it tomorrow afternoon! sub comes in tuesday! :) Edited April 3, 200916 yr by holley2346
