Posted March 30, 200917 yr I just installed 8 brand new cadence comp. speakers, took out the factory speakers. I wanna blow them up, can someone tell me how. I heard that hooking them in 120 volts (regular outlet) will do the trick. Is there an easier way, or another better way? Kinda a goofy random question, and if not allowed on this forum, an admin can just take it off. =] thanks
March 30, 200917 yr Just play around with them..Try hooking one up to an outlet..Think of fun ways..Who knows..
March 30, 200917 yr Author Wall socket or if you have any amps wire it in series or parrallel? which will work better
March 30, 200917 yr Wall socket or if you have any amps wire it in series or parrallel? which will work betterwire all 8 in parallel at .5 ohm into a 120.
March 30, 200917 yr Wall socket or if you have any amps wire it in series or parrallel? which will work betterparallel will blow quicker in a wall outlet. by maybe half a second for factory speakers.but factory speakers arent dual coils. so just do one at a time
March 30, 200917 yr DC kills if the power put out by a battery is greater than the thermal rating of a speaker. You could put a 12V battery on a lot of speakers and never blow it.At a 4 ohm load, a 12VDC battery will only produce only 36 watts.
March 30, 200917 yr If you've got 4 4ohm speakers hook them up in series to a 120v socket. That way you'll only be feeding each speaker 225w instead of the 3600w they'd have to try and handle if you hooked them up individually. They might last a little longer but since you are giving them 10 times more power than they were meant to handle... well let's say there will be more smoke than sound.
April 5, 200916 yr gasoline....12ga buckshot...C4...an assortment of household cleaners...alot of ways to blow up a speaker..but my vote goes to the 60hz shuffle
