Posted April 4, 200917 yr well im about to start my new build some time next week hopefully and im trying to get my electrical squarred away this weekend so here it goes.i recently recieved my new amp (cactus 5kw), and i know it is going to need alot of juice so my plan is to 1.) upgrade my starting battery to a decent car audio battery (everstart maxx, walmart style now) 2.) do my big 3 in 0 ga (haven't done that yet) 3.) run 0 ga to the trunk 4.) one battery in the trunk for sure (d3100) and possibly another if i need it. so far my knu koncepts cart looks like this: 2, 0ga amp kits(for the extra wire, 250amp fuses), 4, battery terminals, 2, 200 amp fuse(for alt and rear batt.), 10 foot of 10ga speaker wire. let me know if i need or dont need anything else please add.also this is the first amp ive owned with two power/ground leads. do i just run a distro-block off my rear battery two 0ga into the amp?thanks Edited April 4, 200917 yr by justiin smith
April 4, 200917 yr you wouldnt normally need to upgrade your starting battery. I'm runnin 5,000w of power and i use stock battery.I see that you didnt mention new alternator.because of this... i wouldnt expect your alternator to last for too long with that kind of current being pulled.You will need more batts than normal because of this.Probably 3 D3100s but the problem is the more batt you add, the longer it's gonna take to charge em all back up.
April 4, 200917 yr Author ive already got a 200amp ho alt for a cop car. but so far my does list look okay?
April 4, 200917 yr someone told me a pair of D3100s will hold up 5k fine.i got one coming, plan on buying a 2nd soon.5k is plan also.
