Posted April 4, 200917 yr Is there anything special to put behind the subs when you drop it into the enclosure so air does not leak between the sub and the front face they are resting in?
April 4, 200917 yr you can ductape.use a type of sealant(i use this caulk stuff thats clear) and wipe it along the gasket.
April 4, 200917 yr If your speaker does not come with a rubber seal you can go to Lowes and buy some weather stripping.
April 6, 200917 yr Author If your speaker does not come with a rubber seal you can go to Lowes and buy some weather stripping.This sounds fine, i have a rubber cover, although it doesn't seem like this would seal it up. These are type r's and it is the rubber cover that come with them.
