April 9, 200917 yr with an Sd or 1029.2 cm^2 and an Xmax of 22mm we get1029.2 * (2 * 2.2) = 4528.48 cm^3 or 4.5 liters of peak to peak swept volume
April 10, 200917 yr You are correct sir. I think the OP is referring to the volume used in a box however. Factor in about 0.12 cubes (if that is the case).Best,Mark
April 10, 200917 yr Author You are correct sir. I think the OP is referring to the volume used in a box however. Factor in about 0.12 cubes (if that is the case).Best,MarkYeah that's what I was looking for, thanks guysIm looking at building what will probably be a 25" cube with 2 2100 gram PRs from CSS
April 10, 200917 yr Im looking at building what will probably be a 25" cube with 2 2100 gram PRs from CSSSweet!
April 22, 200917 yr This works well... Can't say much for in car but I've been running this as a computer sub for a while now and its simply amazing.220 L box with two 1600 g 18" PR's from CSS powered by an EP-1500 which is good for 1200 watts at 4 ohms (tested wattage).As a side note, a SSF might be a good idea. Edited April 22, 200917 yr by Matt5112
