April 11, 200916 yr Author It's just a normal ported enclosure 8.5 net tuned to 35 herts. The port is just flared 45 degrees 5.25 inches from the outside of the enclosure, which is the width of the port. I have seen a little db increase doing this. I guess it would be equivelant to rounding off a port with pvc like in a spl vehicle. The port lenth is measured from where the port 45's inside the enclosure .
April 11, 200916 yr Author On large enclosures I like to use the port for internal bracing for the back wall.
April 11, 200916 yr Author hopefully it won't fall apart Edited April 11, 200916 yr by Audibel Customs
April 11, 200916 yr That is a one nice looking box on the drawing! Can't wait to see the finished box!
April 14, 200916 yr Author This is where it's at right now. I'll wait until the woofer comes in before cut the baffle and finish assembly.
April 14, 200916 yr Damn that's alot of angle cutting, lol. Looks good. I'd like to see the numbers this puts up.
April 14, 200916 yr Author I believe 23 pieces needed to be 45'ed. Wait till you see the 4 15 LI enclosure I got coming.
