Posted April 3, 200520 yr I'd like a box cabinet plan drawn up I don't know if I'm going with this design yet or not, but if I do I'd like to have a plan for it. I'm basically doing a homebrew version of this: http://www.omegaloudspeakers.com/ts33.htmUsing these drivers: http://www.madisound.com/pdf/fostexcabs/fe126e_encl.pdfIf it models well, I wouldn't mind going with a tower speaker instead of a bookshelf - although I don't know exactly how it would react.Thanks...
April 4, 200520 yr Author ***updatedalright, decided to switch drivers...now I'm looking at the upgraded model: http://www.madisound.com/pdf/fostex...s/fe127erev.pdf - end up losing 2dB of sensitivity...woohoo, I'll be at 94dB/1W @ 4 ohms. Plenty of efficiency.http://www.madisound.com/pdf/fostex...27e_revencl.pdf - Recommended Fostex bass reflex enclosure is at the bottom. 10 liters tuned to 71Hz. All I need is a cabinet that fits two of these...
April 4, 200520 yr Author yeah, but they're full range...no tweets...so the tuning naturally is going to be high Trust me, the SQ is there...
April 4, 200520 yr fullrangeness > allno tweets, no crossovers, no problem<{POST_SNAPBACK}>tis trueStill need a SSF though, unless your amp has one
April 4, 200520 yr Author Still need a SSF though, unless your amp has onedoubtful...the amount of power at those frequencies aren't enough to cause overexcursion...
April 4, 200520 yr Author look at the picture i need height, width, depth for a .706 cubic foot internal volumegiven that a single driver's port is 80mm in length by 50mm diameter, what's the port for a box twice as big...and do i need to up the diameter to avoid port noise.
April 4, 200520 yr www.the12volt.comfigure it out yourselfYou wont get any port noise from fullrangersHigh tuning+ low tone+ cone movement= port whistle
April 4, 200520 yr Author so something like that...anyone want to double check my numbers...and what's the darn cutout diameter for a 3" precision port??
