how do you determine how big and what hz they are?
wha'ts that? Im new to the round ports but i like the way they look are they as good as a square port?
They are better because, if you use them right, they make any portnoise.
WinISD is a calculation programm, just throw winisd into google, its a freeware...
You add your driver into the programms database and add your woofers TSP's.
Then you make a new project with your driver and enter the size of your box and the prefered tuning.
WinIsd shows you what diameter of aeroport you should use and the lenght of the aeroport.
Just play with winisd and you'll find out ;-)
A well designed port of either type will not make any port noise.
thats true... :coolugh:
hmm seems none is really better.. sry
