Posted April 19, 200916 yr Why should ohm load matter? Dual 2 is a perfect combination as it can be wired to 1 ohm (which is where most mono blocks produce the bulk of their power).Exactly I only want 1. And Dual 2 Ohm can only be wired to 1ohm & 4 Ohms loads. Where Dual 4 Ohm can be wired to 2Ohms.
