Posted April 19, 200917 yr hi all i was just looking at a cabin gain chart and saw that most vehicles had about 25 db of gain at 25 hz but at 30 hz dropped to about 20 dbs of gain so that got me wondering if i would be better off tuning my box to 25 hz than to 30 hz because of this gain. JW. also does anyone have or know where i can find a cabin gain chart on an 01 tacoma single cab because the chart i have doesnt so i used a dakota insteadthanks mike
April 20, 200917 yr every car has its own freq at which it peaks and that even differ from the same cars and model, while charts can be useful its still best to work out your own.the first peak is where you get cabin gain where the second one normally much higher but you dont get the bennegit of cabin gain and have a narrow freq to work with... normally close to the 50'sTune your box slighly below this freq.I believe there is a good step by step guide on how to work out your cabin gain on SMD forum. Some things take a bit of changing to get right as no two cars are the same.hope this helps some-what
April 20, 200917 yr Author thanks and whats the smd forum and also my truck has a tiny cab so i figured that i would have more gain down low than other cars and when you said to figure it out for my specific car how would i do that, trial and error?
April 20, 200917 yr every car has its own freq at which it peaks and that even differ from the same cars and model, while charts can be useful its still best to work out your own.the first peak is where you get cabin gain where the second one normally much higher but you dont get the bennegit of cabin gain and have a narrow freq to work with... normally close to the 50'sTune your box slighly below this freq.I believe there is a good step by step guide on how to work out your cabin gain on SMD forum. Some things take a bit of changing to get right as no two cars are the same.hope this helps some-whatwhich forum on SMD? SPL? i'm having trouble finding it..
April 20, 200917 yr http://*****.com/home/trail and error is a good way to go about things but dont stick to just one way or the other try and mix and match whatever you try.
April 20, 200917 yr hi all i was just looking at a cabin gain chart and saw that most vehicles had about 25 db of gain at 25 hz but at 30 hz dropped to about 20 dbs of gain so that got me wondering if i would be better off tuning my box to 25 hz than to 30 hz because of this gain. JW. also does anyone have or know where i can find a cabin gain chart on an 01 tacoma single cab because the chart i have doesnt so i used a dakota insteadthanks mikeIt depends on what you want from the subwoofer. Generally, tuning way under 30hz has all the chaces to produce a low-end monster, with exagerated response under 30hz.
April 22, 200917 yr Author hey thanks for the forum and other help and the only thing i wouldnt like about tunning it that low is that there arent many songs that actually reach that low. and im now thinking of tunning my box to 30 hz and using a bunch of port to hopefully get the numbers up
April 22, 200917 yr and im now thinking of tunning my box to 30 hz and using a bunch of port to hopefully get the numbers upWhat is your goal ? High numbers on the sensor or just something to play music ?
April 26, 200917 yr im looking to hit mid 150s but still be hitting the lows decentlyYour going to need POWA.
April 26, 200917 yr im looking to hit mid 150s but still be hitting the lows decentlyYour going to need POWA. And lots of it. Lots of cone area too.
May 21, 200917 yr im looking to hit mid 150s but still be hitting the lows decentlyYour going to need POWA. x2
May 21, 200917 yr Author im thinkin now 2 IA DP21s with a trx 2000d to eachin about 20 to 25 cubes tuned to 30hz
May 21, 200917 yr that should still hit the lows fine if you bump up the tuning a little to low-mid 30's, but i guess that depends on what you mean by lows
May 21, 200917 yr hey thanks for the forum and other help and the only thing i wouldnt like about tunning it that low is that there arent many songs that actually reach that low. and im now thinking of tunning my box to 30 hz and using a bunch of port to hopefully get the numbers upNO. You need to tune higher. If you want loud, tuning that low will not help you.
