April 23, 200917 yr Lol they have different specs, it will not turn out good if you do it. Edited April 23, 200917 yr by patented17
April 23, 200917 yr I say do it. Mixing sizes adds dB's Also, look into mixing brands as well.i hope your joking.
April 24, 200917 yr I say do it. Mixing sizes adds dB's Also, look into mixing brands as well.i hope your joking. x2
April 24, 200917 yr I say do it. Mixing sizes adds dB's Also, look into mixing brands as well.I'm going to castrate you if your serious.
April 24, 200917 yr I say do it. Mixing sizes adds dB's Also, look into mixing brands as well.Make sure they are all in the same box common chamber lol....DONT DO IT.... PICK ONE AND STICK WITH IT... Go 12's
April 24, 200917 yr I say do it. Mixing sizes adds dB's Also, look into mixing brands as well.I'm going to castrate you if your serious. Edited April 24, 200917 yr by DeepSubBoy
April 24, 200917 yr mixing different sizes of subs , will not sound good , it might get loud , but it will sound nasty, each size of sub will be moving at different speeds , some going fast , some slow , it would be nutz , so yeah pick a pair and stick with it,
April 24, 200917 yr It will be bad, nothing to do with drowning out just a completely bad idea.Perhaps you should revisit your threads. Instead of saying, "this or this" describe your goals as your choices aren't really good ones.
