May 24, 200917 yr you need to post these updates on gmfs. whats your elecrical setup? stock? if so hows it holding up?i might be needing an saz-3000 soon. where did you get your amp from? and new or used?
May 25, 200917 yr Author you need to post these updates on gmfs. whats your elecrical setup? stock? if so hows it holding up?i might be needing an saz-3000 soon. where did you get your amp from? and new or used?Stock alt, 2 Big ass batteries in the back and it holds up for now until I get an HO Alt.I got the Sundown 3000D from a Team Member used.
