Posted April 7, 200520 yr This is for 2-10" Alpine Type-R subs (SWR-1022D), and will be powered by an Alpine MRD-M501 amplifier rated at 550W into 2 ohm mono.These are my inside dimensions:Height 10"Depth 10"Width 15.25"Total is .88 ft^3/subTotal outside box dimensions are:11"x11"x32"I need to put this box underneath a rear strut bar and from the bottom of the bar to the trunk floor is 11 1/2". Will this work or should I scrap the strut bar and build a taller box?Any help or suggestions are appreciated.Ed
April 7, 200520 yr This is for 2-10" Alpine Type-R subs (SWR-1022D), and will be powered by an Alpine MRD-M501 amplifier rated at 550W into 2 ohm mono.These are my inside dimensions:Height 10"Depth 10"Width 15.25"Total is .88 ft^3/subTotal outside box dimensions are:11"x11"x32"I need to put this box underneath a rear strut bar and from the bottom of the bar to the trunk floor is 11 1/2". Will this work or should I scrap the strut bar and build a taller box?Any help or suggestions are appreciated.Ed<{POST_SNAPBACK}>0.88 ft^3 is a good size for a Type R 10". If you want a little more room under the strut bar, you can always do a slanted back or front. Give you more room, and you could have the box installed snug to the rear seat. I am assuming that width is for each sub? Two chambers?
April 7, 200520 yr Author Yes, 15.25" is per sub total width would be 32" using 3/4" MDF. I was just kind of worried about the height of the box compared to the 10" sub.Ed
April 7, 200520 yr Yes, 15.25" is per sub total width would be 32" using 3/4" MDF. I was just kind of worried about the height of the box compared to the 10" sub.Ed<{POST_SNAPBACK}>If you are worried, do a slanted side (where you will mount the subs). Here is a calculator: http://www.bcae1.com/spboxnew2.htmA little harder to make, but allows for easier implementation in your case.
April 7, 200520 yr Author Cool, I'll try that when I get home from work. If you thinkmy size will work, I'll probably stick with that. I'll mess with the link you gave me and see what it comes up with. Thanks,Ed
