Posted April 27, 200916 yr i got bored and decided to draw this up, its right around 2.5 cubes @ 35 hz. gonna be for two 10's ( AQ SDC2.5's) Its gonna go in my chevy std. cab.Any comments or suggestions?
May 6, 200916 yr Doesn't look like your gonna be able to mount the subs in that box. How deep are the SDC's.(I know but I want you to go look. LOL)
May 6, 200916 yr Author Doesn't look like your gonna be able to mount the subs in that box. How deep are the SDC's.(I know but I want you to go look. LOL)i think they'll fit, itll be close, if it dont, im just gonna do a double baffle on it
May 6, 200916 yr just make sure that it has enough room to breath or the voice coil will over heat and cook
May 6, 200916 yr just make sure that it has enough room to breath or the voice coil will over heat and cookx1000000000
May 23, 200916 yr just make sure that it has enough room to breath or the voice coil will over heat and cookx1000000000 x2
May 23, 200916 yr i got bored and decided to draw this up, its right around 2.5 cubes @ 35 hz. gonna be for two 10's ( AQ SDC2.5's) Its gonna go in my chevy std. cab.Any comments or suggestions?I know the AQ's sdc2.5 work in a 2.0cuft box so I think it will work.
May 23, 200916 yr Is it 2.5 cuft NET? It should be right around 3.0 cuft including driver disp. and port volume.
