Posted May 1, 200916 yr If I have my Pioneer 5000Ub headunit with LPF set at 80 Hz.Will I also have to set the Amp Low Pass Filter or can I leave it all up to the Headunit?
May 1, 200916 yr since your using the hu's xover u just have to keep the amp's filter above that setting, so id just turn it as far up as it goes or turn it off
May 1, 200916 yr What if the head unit has a pass through option? which crossover is better the head unti or the amp?
