May 5, 200917 yr Author i pushing it with a 3500mmats they only 1000rms what should i do to prevent it ?
May 5, 200917 yr i pushing it with a 3500mmats they are only 1000rms what should i do to prevent it ?lol and what does ur electrical consist of
May 5, 200917 yr Adjust your amplifier settings the right way.x2 plus be sure your electrical is capable of with standing the current draw from your amp or you ultimatly end up clipping and burning them
May 5, 200917 yr wire gets burnt due to excessive current. Of course, manufacturer has the right amount of wire in there to handle the loads that will be given to the sub. A lot more power than rated. the problem is when the voltage going into the amp starts to become too low or the amp starts to clip, these result in higher than normal current outputs from the amp.
May 5, 200917 yr wire gets burnt due to excessive current. Of course, manufacturer has the right amount of wire in there to handle the loads that will be given to the sub. A lot more power than rated. the problem is when the voltage going into the amp starts to become too low or the amp starts to clip, these result in higher than normal current outputs from the amp.thanks for elaborating i didnt feel like doing it
May 5, 200917 yr I use insane power on my subs and I have never seen a tinsel lead burnwith a clean signal...you were definately clipping the hell out of your amp...
May 5, 200917 yr Author i runing the dreadnuts mmats 12"I see like u used some thing to cover the wire what did u used?
May 5, 200917 yr He didn't use something to cover the wire, he replaced the wire with a larger gauge.
