Posted May 6, 200916 yr I have a Soundstream TRX 4.420,it puts out 70 watts rms x 4 channels @ 4 ohms, and 105 watts rms @2 ohms.------I have 2 sets of infinity's that run at 2 ohms,1 set of 6x9s rated at 105watts rms, and 1 set of 5 1/4 componets rated @ 75 watts rms. If I added 2 more sets and wired them together ass if it was 4 seperate dual voice coil subs in series each on there own channel would each speaker get 70 watts? or would each speaker get 35 watts? or would my amp burn up, even though it can run a 2 ohm load from running 8 speakers 2 for each channel? is this possible----------------Question #2 If this is a bad idea, and I probally will not do this anyway I was just wondering If this is possible, If I turn my front gain down alot, will it be safe running my 5 1/4's @ 2 Ohms? If the gain is turned down enough, will it put out less than 75 watts? I hear alot of people saying that gain is just a way to dial in your amp, and it can put out the same power regardless, if it is set to 8 volts, or 1 volt. Edited May 6, 200916 yr by Dangerous10k
May 6, 200916 yr I have a Soundstream TRX 4.420,it puts out 70 watts rms x 4 channels @ 4 ohms, and 105 watts rms @2 ohms.------I have 2 sets of infinity's that run at 2 ohms,1 set of 6x9s rated at 105watts rms, and 1 set of 5 1/4 componets rated @ 75 watts rms. If I added 2 more sets and wired them together ass if it was 4 seperate dual voice coil subs in series each on there own channel would each speaker get 70 watts? or would each speaker get 35 watts? or would my amp burn up, even though it can run a 2 ohm load from running 8 speakers 2 for each channel? is this possibleAnswer these questions and then i can help u more..INFINITY'S --- What impedance6x9's --- What impedance5 1/4's --- What impedanceINFINITY'S --- single or double voice coil6x9's --- single or double voice coil5 1/4's --- single or double voice coilAlso how many total speakers are u trying to use??
May 6, 200916 yr Get a second amp for the additional speakers. Or better yet, don't put them in. Why do you need 4 pairs of speakers in there?But to answer the question, you'd have to wire two speakers in series, giving you a total of four 4 ohm loads, assuming the new speakers you get are also 2 ohms. If you put each pair of speakers on a channel, each speaker would get 35 watts.
