Posted May 13, 200917 yr Yet another question by me hopefully you guys can help me outWould i be able to run an SAE-1200d for my two 12" Lethal Injections and a RF p5002 for a pair of Re Audio components (it will run at 4 ohms, 125watts each) on a stock alt (110amps) with the big three done? Edited May 13, 200917 yr by davidg121
May 13, 200917 yr Author and also do you think that thats too much to be putting to the re components?
May 13, 200917 yr and also do you think that thats too much to be putting to the re components?not sure but i would recomend atleast an extra bat and a nice one up front... if you can get an alt thats alot of power to run off stock in my op..
May 13, 200917 yr Author now im not sure of this... but ive heard that putting batteries in a trunk releases gas's and what not and is dangerous to do... Is this true or is it just certain batteries that does it
May 13, 200917 yr now im not sure of this... but ive heard that putting batteries in a trunk releases gas's and what not and is dangerous to do... Is this true or is it just certain batteries that does itif you have dry cell batts/ then you ewont have that problem. try remybattery.com and look at the dekas
May 13, 200917 yr now im not sure of this... but ive heard that putting batteries in a trunk releases gas's and what not and is dangerous to do... Is this true or is it just certain batteries that does itif you have dry cell batts/ then you ewont have that problem. try remybattery.com and look at the dekaskenetics and even optimas try for yellow tops if you go that route.... dont put an acid battery in the car truck cabin ect... if you dont get poisend you will have a chitty mess to clean up lol
May 13, 200917 yr Author heh yeah thats what i figured... Now please correct me if im wrong... but adding another battery would only increase the amount of time i can use my system when the car is off right... I never play my system with my car off, so would this really even be necessary?
May 13, 200917 yr heh yeah thats what i figured... Now please correct me if im wrong... but adding another battery would only increase the amount of time i can use my system when the car is off right... I never play my system with my car off, so would this really even be necessary?Yes a better battery bank will allow you to play the system for longer while it was off although i wouldnt recomend it. The idea of adding another battery in this case is to keep your voltage up during normal listening not to run while the car is off. It dosnt only allow longer playing time while the car is off.
