May 16, 200916 yr Author Admin 60/40 or bench seat?I think it's a bench seat, not sure yet. I'm just assuming.
May 16, 200916 yr Author Admin 60/40 or bench seat?I think it's a bench seat, not sure yet. I'm just assuming.also, this guy is stopping over later for some box ideas, just wanted to be prepared.
May 16, 200916 yr 60/40 or bench seat?I think it's a bench seat, not sure yet. I'm just assuming.Noob!
May 16, 200916 yr I don't have any plans on hand but if It's:40/60 it'll have the bars under the seat. The best set-up I 've done was a twelve ported downfired on the driver side with the enclosure streching across tho the passenger side. If you let the magnet protrude through the top of the enclosure and fiberglass a "bubble" to cover it you can get about 7 inches of mounting depth and still have 1 1/2 between the sub and the floor. I do believe I raised the seat 1/2 with washers though.bench seat you will have 54 inches wide, 7 inches at the front of the seat, 5 1/2 inches at the rear of the seat and 19 inches on each side of the center hump. again if you are doing SSA subs you will have to make a bubble to let the magnets protrude out the top of the enclosure. two tens ported work very well. You'll have about 2.5 cubes to work with with out raising the seat any.
May 16, 200916 yr Author Admin 60/40 or bench seat?I think it's a bench seat, not sure yet. I'm just assuming.Noob! yup. guilty. seriously though, anyone have any?
May 16, 200916 yr Author Admin I don't have any plans on hand but if It's:40/60 it'll have the bars under the seat. The best set-up I 've done was a twelve ported downfired on the driver side with the enclosure streching across tho the passenger side. If you let the magnet protrude through the top of the enclosure and fiberglass a "bubble" to cover it you can get about 7 inches of mounting depth and still have 1 1/2 between the sub and the floor. I do believe I raised the seat 1/2 with washers though.bench seat you will have 54 inches wide, 7 inches at the front of the seat, 5 1/2 inches at the rear of the seat and 19 inches on each side of the center hump. again if you are doing SSA subs you will have to make a bubble to let the magnets protrude out the top of the enclosure. two tens ported work very well. You'll have about 2.5 cubes to work with with out raising the seat any.thanks for the guidelines, anyone else?
