Posted May 16, 200917 yr which would you choose for a ported box? amp would be a US AMPS MD1D (1200w RMS @ 1 ohm).
May 17, 200917 yr goals? the Mach 5 is geared more towards sound quality, while the lvl4 is geared more to get loud
May 17, 200917 yr what do you plan for tuning and what music do you listen to if you listen to rap and tuning between 32-34hz both would be good if you tune higher go with the lvl4 if you go with a lower tuning go with the ixl for rap id pick the lvl4 and tune to 36hz it will slam and get decently low for rap if you listen to a lot of the slowed and like it a little lower the ixl at 32 would do a nice job
May 17, 200917 yr Author goals? the Mach 5 is geared more towards sound quality, while the lvl4 is geared more to get loudi want something that gets loud but also sounds good. i listen to rap and country
May 18, 200917 yr Author also how would the ssa 10" icon compare? might have to take advantage of the audibel customs buy a sub get a free box combo
May 18, 200917 yr Admin also how would the ssa 10" icon compare? might have to take advantage of the audibel customs buy a sub get a free box comboICON would be right at home with above mentioned goals. And is an unbeatable deal with the free enclosure that comes with it from Audible Customs. I would jump on it before May 22nd or you won't get that deal.
May 18, 200917 yr Author also how would the ssa 10" icon compare? might have to take advantage of the audibel customs buy a sub get a free box comboICON would be right at home with above mentioned goals. And is an unbeatable deal with the free enclosure that comes with it from Audible Customs. I would jump on it before May 22nd or you won't get that deal. sounds good but would i have to leave room for the pole vent? i have limited space so the max mounting depth i can do is about 6.5"
