May 28, 200917 yr I want to run two BLs on two 1500d-SAZ. What kind of RCAs would i need.Need a little more info..Are u going to have 1 amp on 1 sub sub??Or are you going to have the amps strapped and have the subs wired together?? -- in this state the lowest impedance can only be 2 ohms!! Edited May 28, 200917 yr by sqjeep
May 28, 200917 yr Author I want to run two BLs on two 1500d-SAZ. What kind of RCAs would i need.Need a little more info..Are u going to have 1 amp on 1 sub sub??Or are you going to have the amps strapped and have the subs wired together?? -- in this state the lowest impedance can only be 2 ohms!!My head unit is a PIONEER DEH-P6000UB and i want to run a each amp and each sub.
May 28, 200917 yr I want to run two BLs on two 1500d-SAZ. What kind of RCAs would i need.Need a little more info..Are u going to have 1 amp on 1 sub sub??Or are you going to have the amps strapped and have the subs wired together?? -- in this state the lowest impedance can only be 2 ohms!!My head unit is a PIONEER DEH-P6000UB and i want to run a each amp and each sub.Y-splitters are the first to pop into my mind. Or maybe you could add an EQ or something to that effect, that can split outputs while maintaining some sound quality. Edited May 28, 200917 yr by DeepSubBoy
