Posted May 28, 200916 yr Im thinking about running 2 american bass xfls at 1 ohm off of the kicker amp good idea i know its not but will it work?edit the subs only come in dual 4 ohm VCs Edited May 28, 200916 yr by firtyfwe
May 28, 200916 yr No, that won't work. You'll end up blowing the amp and having to buy a new one anyhow. So you might as well just skip the blowing up step.
May 28, 200916 yr No, that won't work. You'll end up blowing the amp and having to buy a new one anyhow. So you might as well just skip the blowing up step....since when are kicker amps not rated @ 1ohm?
May 28, 200916 yr no shit? i've never had any problems running kicker amps @ 1ohm, never had a customer return, blown amp, nothing. then again these were all zx1000.1's and below installs. *shrugs*
May 28, 200916 yr Admin well the one time I tryed it figured it would be no big deal and poof it went.
May 28, 200916 yr No, that won't work. You'll end up blowing the amp and having to buy a new one anyhow. So you might as well just skip the blowing up step....since when are kicker amps not rated @ 1ohm?As long as I can remember the ZX series has been 2ohm stable. A 1500w amp is a 1500w amp though.
